URL to PDF
cwswitch
URL to PDF
Post by cwswitch » Sun Feb 18, 2018 11:48 pm
Already I can get a job ticket/job bag as a webpage from our MIS. Printing the PDF to the required desktop printer is already solved.
What I'm looking to do now is convert that webpage to a PDF so I can print it.
I have seen numerous websites that offer this facility, but not the kind of thing I can use with Switch.
I have a silly idea to do all this in an Ubuntu virtual machine, but that is a long process and a silly overhead just to achieve this.
Switch is running in a Windows box
Any ideas welcome! Thanks
Padawan
Re: URL to PDF
Post by Padawan » Mon Feb 19, 2018 10:25 am
It looks like this tool can do the job:
https://wkhtmltopdf.org/
It's a command line tool, so you should be able to use it using the Execute Command tool or via Switch scripting.
I haven't tried it myself, so I'm not sure on the quality.
Also, the webpage gives an example with a live url, if you want it to work with html pages, then you will have to use the stuff said here:
https://stackoverflow.com/questions/455 ... local-file
cwswitch
Re: URL to PDF
Post by cwswitch » Mon Feb 19, 2018 9:17 pm
Excellent thanks. This had popped up in searches yesterday but I had got distracted with other options - the most promising of which seemed like Chrome Headless.
But yes, wkhtmltopdf seems to at least grab the page and make a PDF, which is excellent!
Now for the username, password, and all the other joys..
Many thanks
rick1221
Re: URL to PDF
Post by rick1221 » Thu Jan 03, 2019 8:48 am
I was also looking for the answer to convert the URL file into the PDF file and I got to know from here what are the main things that need to be done. Converting the webpage to the pdf can be accessed.
