Filename PDF same as record CSV
dennismeyer
Post by dennismeyer »
Hi all,
For one of our customers we have a flow to create entrance passes.
The income database (csv) have a structure like below:
Name - Employeenumber
1. Dennis - 123
2. Pieter - 567
etc...
We use HP Smartstream configurator to make the PDF, and the export is somewhing like: Indesignfilname_record1 etc...
The customer want to have this Filename: Dennis 123.pdf
Is it possible with scripting or anything else.
sander
Re: Filename PDF same as record CSV
Post by sander »
If your output contains name_RecordNumber.pdf or something I would lookup the RecordNumber in the csv and rename accordingly.
NEOSA
Post by NEOSA »
May be using CSV2XML from the AppStore ?
Do you pass all the job at the same time ?
As explained by sander, may be also using a Rename tool, with a regEx to search a certain pattern, and rename with regEx also ?
Search for :
([A-Za-z0-9]*)_([A-Za-z0-9]*)_([A-Za-z0-9]*)_(.*)
Replace by :
\2_\3_\1
(this is an example)
Kermy812
Post by Kermy812 »
I have used "A Better Finder Renamer". It's great - it has a lot of remanning tools that you'll be amazed at. You'll have to use the function called "Rename from List from list". You'll make a list with the current name in 1 column, then put what you want it to be in the column 2, save as a text tab delimited file. Import the text file into ABFR, then drag n drop the pdfs to rename.
http://www.publicspace.net/ABetterFinderRename/
james121
Post by james121 »
I wish I saw this information sooner
Hello guys, I'm James from JSON formatter online team. Our projects are: roll the ball and slope game . Hope your help, thank you!
