Error with my Adobe Acrobat Pro 8
mlongo
Post by mlongo »
I have Acrobat 8 Pro installed on my Switch server. I can run this application manually without any issues. But within Switch, I cannot get my Adobe Acrobat Professional application to run. I receive the following error: "Warning - Flow validation error: the application is not available on the Switch server." I have already tried several times to right-click on the application and use the "Set Path to Application" feature and point the application to the install location. But the system continues to fail with that error. Any suggestions are welcome.
Thanks!
mlongo
Re: Error with my Adobe Acrobat Pro 8
Post by mlongo »
Just wanted to add an update that we located a license for DC and installed that version. This solved the problem we were having.
Thanks!
