Simple Word to PDF Workflow-Problem
Scag
Post by Scag »
Hello everyone,
for testing a new Workflow I just tried simply creating a PDF-file out of my Word (*.doc)-file.
Simple workflow: Input (all file-types get transferred) - Word (save as PDF, no Macros) - Output.
But what switch does is just renaming the Word-file I copied into the input-folder and leaving it there, not moving to problem-jobs, not creating the PDF-file.
As I'm really unexperienced with switch I actually don't see my mistake. Might it be because the MS Word-Version installed on the server is a 30-days-trial? Or what else am I doing wrong?
I hope you can help me, please excuse my partially poor english, I'm not a native speaker.
Terkelsen
Re: Simple Word to PDF Workflow-Problem
Post by Terkelsen »
My experience is, that this usually happens due to restricted user rights. Try checking if the user that runs Switch has the correct read- and write permissions to these files.
NewScag
Post by NewScag »
Thank you for the response!
But that unfortunatelly does not solve my problem...
Writing a file with Adobe Acrobat Pro works (but this sadly cannot open doc-files ;) )
More suggestions would be really nice, I'm still working to fix that problem.
NewScag
Post by NewScag »
Update: After about an hour Switch moves the File to Problem-Jobs, saying the Job was aborted because the process took too long.
Doesn't solve my problem but maybe a hint to the solution... :(
NewScag
Post by NewScag »
Update: No solution yet, please help!
mattbeals
Post by mattbeals »
try using callas pdfToolbox Server. It has a built in Word to PDF conversion function.
NewScag
Post by NewScag »
Thank you a lot, I'm pretty sure this would solve my problem.
But unfortunatelly, regarding the costs, this is not an option for me.
As there is (or should be) a way to convert files directly with MS Word (or more specific: the configurator), I actually want to use this tool.
At the moment I am using MS Word 2013, any experience with this?
I'll try downgrading it to 2010 or 2007 soon, maybe this is a hint...
I'm always happy for new tipps!
thomas_zg
Post by thomas_zg »
I made a workflow with the Word configurator and Office 2010, I had only once the situation you're describing and the solution was to recreate the document. The workflow made a least 10000 convertions to PDF the last year.
The only difference was, that we're working with docx.
Best regards,
Thomas
NewScag
Post by NewScag »
Found the solution:
Switch Watchdog must not run as a system service.
Now everything is just working great, thank you everybody for your replies.
Thread can be closed.
mattbeals
Post by mattbeals »
Must "NOT"? Watchdog is an important piece of Switch to gave running as a service.
thomas_zg
Post by thomas_zg »
Have also a look at http://www.enfocus.com/en/support/knowl ... s-Service/.
Best regards,
Thomas
3f8h.net
Post by 3f8h.net »
You may run the switch watchdog under a named user. This user should have access to your office installation.
Sebastian Nafroth +++ 3f8h.net / electronic publishing
3f8h.net offers professional services and products for the graphic arts
industry.
contact details: http://www.3f8h.net/kontakt
