Does anyone know if the smartsrteam design can be used to output different files? We have a client that wants a separate PDF for each record. My first thought is, just split it within Switch. But they want the files named according to a variable in the database, so I'm not sure how to make that happen.
Any ideas?
Smartstream Question
Re: Smartstream Question
And to simplify this question: can you pull text out of a PDF via Switch or Pitstop? If so, we could tie the variable to a hidden field in the PDF.
Answer to this, you can use PdfSpy from Apago. It has an function that reads text and make it metadata.. Have used it with some jobs.gabrielp wrote:And to simplify this question: can you pull text out of a PDF via Switch or Pitstop? If so, we could tie the variable to a hidden field in the PDF.
Between jobs!
I got this from Dwight at Apago..
// PDFspy text search
// (c) 2012-2014 by Apago, Inc.
// All rights reserved
// Created by Dwight Kelly <dkelly@apago.com>
// Date: 2012/01/20
// Modified: 2014/11/31
// Switch logging & output levels
const cLogAssert = -2;
const cLogDebug = -1;
const cLogInfo = 1;
const cLogWarning = 2;
const cLogError = 3;
const cLogProgress = 5;
const cSendSuccess = 1;
const cSendWarning = 2;
const cSendError = 3;
function isolate( job : Job, str : String, matchPos : Integer ) : String
// trim left side
if (matchPos > 1)
str = str.substring(matchPos);
var ltPos = matchPos;
if (str.charAt(ltPos) == ' ') // watch out for leading spaces
ltPos++;
var parts = str.split(" ");
if (parts.length > 1)
return parts[1];
return "";
if (job.isFolder()) {
job.fail( "This configurator cannot handle job folders" );
return;
if (!job.isType("pdf")) {
job.fail("This configurator only supports PDF");
return;
var appPath;
if (s.isMac())
appPath = "/Applications/pdfspy/pdfspy";
else
appPath = "c:/Program Files (x86)/Apago/PDFSpy/pdfspy";
var String args = new Array();
var argc = 0;
args[argc++] = appPath;
args[argc++] = "-text";
var String outFile = job.createPathWithExtension("txt", false); // output file
args[argc++] = "-o";
args[argc++] = outFile;
args[argc++] = job.getPath(); // input file
var exitStatus = Process.execute(args);
if (exitStatus != 0) {
// failure
job.log(cLogError, "Could not extract text from PDF");
job.sendToData( cSendError, job.getPath() );
return;
if (!File.exists(outFile)) {
// failure
job.log(cLogError, "Could not open text file " + outFile);
return false;
var textFile = new File( outFile, "UTF-8" );
textFile.open(File.ReadOnly);
var theMarker = s.getPropertyValue("marker");
var theSearchType = s.getPropertyEditor("marker");
var theRegEx = (theSearchType == "Single-line text") ? theMarker : new RegExp(theMarker);
var cnt = 0, matchPos;
do {
var line = textFile.readLine();
if (cnt++ == 0 && line.charCodeAt(0) == 0x0c) {
// blank page
textFile.close();
var jobid = job.getNameProper().split("_");
job.setPrivateData("ExtractedName", jobid[0]);
//job.log(cLogInfo, "Blank page '" + jobid[0] + "'");
job.sendToData( cSendSuccess, job.getPath() );
return;
matchPos = line.search(theRegEx);
if (matchPos >= 0) {
line = isolate(job, line, matchPos);
if (line.length > 0) {
textFile.close();
job.setPrivateData("ExtractedName", line);
job.log(cLogInfo, "Extracted name = '" + line + "'");
return;
} while (!textFile.eof);
// failure
textFile.close();
job.log(cLogError, "Could not find the marker text");
Between jobs!
Thanks man. I'll look into PDFSpy.
No problem, glad if it helped!
And as an example you use the "Marker" text as trigger. It looks for that text and to the next "space" I think it was..
Between jobs!
Got it working today with some help from Dwight. Thanks Lombert. PDFSpy is super useful.
