Hello all,
I am trying to connect to my submit files via SwitchClient to my Switch Server that is located on the same network but on a different computer. If I understand correctly, when you push the discover button in SwitchClient it will display found Switch Servers. This did not happen when I pressed the button. I tried to connect by manually entering the address, but it still was not found. Any help is appreciated.
Access Switch from another computer through SwitchClient
Re: Access Switch from another computer through SwitchClient
That is how it should work. Sounds like you may have some networking issues. Are the computers on the same subnet? Can you ping the Switch server from the other machine? I haven't experienced this issue, but perhaps the Switch Client and Switch Server versions need to be the same, so check that too.
If I've helped you and you'd like to say thanks, consider adding me on LinkedIn and leaving me an endorsement or recommendation. It helps a lot!
