Adding "description" to switch client panel + first page after login
RytisT
Post by RytisT »
Hello, good people.
Was customizing switch submit jobs menu/point thingy, when I stumbled across that in switch designer, you can enter description to a submit point (http://prntscr.com/kkmt6v) was wondering, maybe it's possible to add that description to submit point on switch client, panel? (http://prntscr.com/kkmtd0) I know it's a simple HTML, but I don't really know html that well, I don't even know what would the code for that description be, since it's nowhere to be found on switch client webpage as far as I know. Has anyone ever maybe tried this?
Also, is it possible to change and if yes, maybe anyone knows how, so when people login to switch client webpage, the first page that would open would be submit jobs? Since now, when people login first page that opens up is either messages if they have that enabled or check jobs. Anyone? Thanks!
essexmate
Re: Adding "description" to switch client panel + first page after login
Post by essexmate »
You can add the following link to your browser bookmarks to make 'Submit jobs' your first page after login.
http://yourSwitchServerIPaddress:51089/ ... bmitpoints
All our prepress operators use this link.
