HP SmartStream Designer 14.0.6 for InDesign CC 2019
Posted: Mon Dec 03, 2018 5:18 pm
by essexmate
The new installer is now available:
HP SmartStream Designer 14.0.6 for InDesign CC 2019 Mac
https://www.printos.com/knowledge-zone/ ... sset/38202
HP SmartStream Designer 14.0.6 for InDesign CC 2019 PC
https://www.printos.com/knowledge-zone/ ... sset/38203
Re: HP SmartStream Designer 14.0.6 for InDesign CC 2019
Posted: Wed Jun 26, 2019 4:06 am
by DomCooper
Can anyone confirm that this version of SS Designer is compatible with the available Switch Configurator? I can't seem to get it to work in our environment.
Posted: Thu Jun 27, 2019 5:24 pm
by cstevens
The developer told me that Designer 14.0.6 (which supports CC2019) is supported by version 140 of the Configurator (which should be the latest on the Enfocus website). If you're having issues with it working and you are using this version then check that you have Adobe "Extendscript Toolkit CC" installed.
If that still doesn't work make sure you don't have multiple versions of InDesign installed on the system.
Posted: Tue Jul 02, 2019 3:59 pm
by essexmate
Yes it definitely works with Switch Configurator. We use it every day. Occasionally we do have a timing problem the first time the configurator is used if InDesign was not already open in the background. I now have InDesign open on my switch server.
A newer version of Smartstream Designer 14.1 is available now which corrects a few bugs in the earlier version:
https://h71044.www7.hp.com/ga/2009/us/e ... signer.php
Posted: Tue Jul 02, 2019 4:12 pm
by essexmate
I forgot to add, the configurator requires Adobe InDesign + SmartStream Designer +
Adobe ExtendScript Toolkit in order to function properly.
Look for
ExtendScript Toolkit CC for Windows (32bit) and Mac OS (64bit) here:
https://creative.adobe.com/products/estk
