Switch 2019 Spring Edition
Has anyone updated to the Spring edition of Switch yet?
Any issues?
I'd like to go to Switch 2019, but with 80+ flows running on the production server I thought I'd ask before I jump in head first...
In the past I've had issues with the PitStop Server configurators not finding their action lists after upgrading...
Any issues?
Re: Switch 2019 Spring Edition
I am waiting on someone else to take a plunge first.
Based on previous experience, it is not worth the trouble, better wait than be sorry.
Once bitten, twice shy
Been there, done that... Twice...
did the upgrade from Switch 2018 update 3 to Switch 2019 and can report no issues so far. Also running PitStop Server 2019, all flows running like they sould
Thanks Vernon.
That's the information I was looking for!
Now I can go ahead and update Switch.
Hi All,
I met an issue : Web Portal metadata not working for user
A customer that had a log of submit point/checkpoints and couldn't see metadata when submitting.
This will be fixed in the next release of Switch.
Enfocus has a workaround, ask Support for the fix if relevant.
Observed on a macOS version of Switch.
Not seen any reported issues of Switch/PitStop Server issues with the upgrade.
You can take it from me that part was extensively tested after the previous issues.
abc@imposition.com
abc@imposition.com
- JimmyHartington
I did the update today, Sunday. Snapshots and backups first. Closed all the applications and start the update of Switch, Pitstop Server and Pitstop Pro. At this moment everything is running fine again (Windows Server 2012).
Working with: Enfocus Switch, Pitstop Server, Quite Imposing, Kodak Nexpress (max 640mm sheets and 500grs) with most options (HD, Clear, Gold, White, Light-Black and Matt fuser), Polar Mohr D80 (compucut), Multigraf, Heidelberg, GMP, Duplo, Hohner.
Just to report that I took plunge this last weekend and upgraded Switch to 2019 Spring edition.
I run into issue with Submit Points.
None of Submit Points updated properly and did not work (I used latest "fixed" installer).
I had to add brand new Submit points from scratch and copy/paste properties from old ones.
That was my workaround.
I had only 4 or 5 Submit points so it was not big of a deal.
Other than this glitch, everything seems stable so far.
I took the plunge a while back and I haven't had any issues yet.
After checking the Switch system requirements for Switch 2019, I noticed that 2012 Server R2 is no longer listed as a supported system. Is anybody using Switch 2019 with 2012 Server R2? If so has anybody ran into any issues?
