Ignore folders in PowerSwitch
Stephen_Smith
Post by Stephen_Smith »
Does PowerSwitch have the capability of ignoring folders? My flow is picking up both files and folders.
Thanks,
Stephen
matb
Post by matb »
Hi Stephen,
This can be achieved using the restyled Submit Hierarchy tool in Switch 09, using the following settings:
- Subfolder levels: 1
- Process these folders: All folders
- Adjusted by (rule 1): Excluding folders named
* Folder name: Regular expression (being .* (dot-star) which matches all folder names)
* On levels: 1
* Restriction: None
* Nesting: Exclude nested subfolders as well
This will process everything, except for all folders and their subfolders - which is the same as processing only the files.
Using the Submit Hierarchy tool will ignore all folders completely, they won't be renamed/changed/moved at all.
Hope this helps!
