Activation "AWS S3 Download"
Posted: Wed Dec 16, 2020 4:07 pm
by schmitzdp
I'm trying to enable "AWS S3 Download" on Switch. I also installed and configured "AWS CLI".
However, I get this error message:
Is there anything I forgot?
(I have already restarted my PC under windows.)
Thank you.
Re: Activation "AWS S3 Download"
Posted: Wed Dec 16, 2020 7:08 pm
by mkayyyy
I ran into the same issue with the AWS S3 Download app
The only way I ended up getting it to work was by using the script version from here: https://github.com/open-automation/switch-aws
Posted: Sun Dec 20, 2020 11:36 am
by schmitzdp
mkayyyy wrote: Wed Dec 16, 2020 7:08 pm I ran into the same issue with the AWS S3 Download app
Even with this script, I have the same error result.
However, here is what I get in the command prompt
C:\>aws --version
aws-cli/2.1.11 Python/3.7.9 Windows/10 exe/AMD64 prompt/off
Does anyone have an idea? Thank you
Posted: Fri Dec 25, 2020 3:34 pm
by schmitzdp
Up :?: :idea:
Posted: Wed Jan 06, 2021 12:22 pm
by schmitzdp
Finally, I used the suggested version of the script. Then I modified this script because the "AWS CLI" check was actually blocking the download.
Posted: Mon Jan 18, 2021 3:06 pm
by mkayyyy
Apologies for the delayed reply, glad you were able to sort it in the end!
Posted: Wed Aug 04, 2021 6:41 pm
by Farva
I am currently having this issue as well. Could you share the updated script or does anyone else have a solution?
Posted: Tue Sep 13, 2022 12:53 am
by MY001
Anybody found a solution for this?
@schmitzdp could you please share what adjustment you did on the code to make this work?
Posted: Tue Sep 13, 2022 12:08 pm
by schmitzdp
in the script, I deactivated what was related to AWS CLI, if I remember correctly
https://www.schmitz.be/S3%20Download.sscript
Posted: Tue Jan 30, 2024 10:21 am
by Jiyahana
yeah it's great to hear that you find you solution and if you wand some more information then please visit this documentation.
