HP SmartStream Designer 160 and output to randomish folders
antipodes
Post by antipodes »
Running Switch 2021 Spring with SmartStream Designer 160, and InDesign 16.3.1 with SmartStream Designer 16.0.8, all on macOS 11.4.
My problem is this: once InDesign has created the output file (jlt, pdf, either), it will then quite often deposit it seemingly nowhere, only for it to then appear next time the SmartStream Designer runs, where it will place both the older output file and the new output file in the outgoing directory — even if they are part of completely different flows.
Does anyone else get this, and does anyone else have a fix?
Thanks in advance.
