Fullswitch 08 update 8 does not show actions from photoshop CS4
FPbrown
Post by FPbrown »
Hello all,
As the subject says Fullswitch does not show my actions list.
I use OS X 10.6.3 , Fullswitch 08 update 8 , photoshop CS4.
I read a topic in this forum where they say the problem is that Fullswitch 08 is not conform with OS X 10.6.3 and that you should update fullswitch 8 to version 9.
Look below:
the reason why you don't see Photoshop actions is because you are running this combination of software on SnowLeopard. This platform is not supported for Switch 08 and there are indeed known issues with all Adobe configurators when using the software on SnowLeopard.
The good news is that this can be easily solved by upgrading to Switch 09. You can download the free and fully functional trial from our website and use it for 30 days already. Just remember to purchase the upgrade before your trial ends if you need to have this combination working in your productio
But, i have worked with it before multiple times without a problem.
The problem was that my hard disk where i used fullswitch ( OS X 10.6.3) crashed.
I bought a new hard disk with same version re-installed photoshop and fullswitch.
Re-added my actions in photoshop and re-added my flows in fullswitch.
After re-install of fullswitch which was version 08 update 4, i updated it to 08 update 8.
And now fullswitch cannot find the actions.
Does any one have an idea of the problem?
Thanks in advance,
Peter.
