replace xml values with switch values
sander
Re: replace xml values with switch values
Post by sander » Wed Jan 20, 2016 11:14 am
I would read the entire XML, replace whatever you want, write back to a new file.
Replace whatever value you want like I do with the lineBreaks over here;
		// Get propertyValue
		var privateDataKey = s.getPropertyValue('PrivateData');
		// Create file with Windows-1252 coding, needed for certain characters
		var readBody = File.read(job.getPath(), "Windows-1252");
		// Replace LF with CRLF, Prodist needs CRLF for correct parsing of e.g. addresses
		var replaceLineBreak = readBody.replace(/\n/g,"\r\n");
		// Put body in private data
		job.setPrivateData(privateDataKey, replaceLineBreak);
Part of my playground:
- HP Indigo 12.000 | HP Indigo 10.000 | HP Indigo 7600's | HP Production Center
- Scodix Ultra 2 Pro | Highcon Euclid III | CP Bourg booklet maker (inline w/ 7600)
sander
Post by sander » Wed Jan 20, 2016 2:24 pm
Haha fair enough. I just copied this script as reference/idea for the replace part.
Just tested and came up with this one.
	// Read properties
	var oldValue1 = s.getPropertyValue('oldValue1');
	var newValue1 = s.getPropertyValue('newValue1');
	// Read incoming XML
 	var oldXML = File.read(job.getPath(), "Windows-1252");
	// Create new XML
	var newXML = job.createPathWithName(job.getName());
	// Replace stuff
	// These properties can easily be filled via standard Switch properties, see screenshot.
	var newXMLcontent = oldXML.replace(oldValue1,newValue1);
	// Write new XML
	File.write(newXML, newXMLcontent, 'Windows-1252');
	// Send newXML to output
	job.sendToSingle(newXML);
oldXML input:
<print duplex="yes" sides_printed="4/4" sides_printed_text="dubbelzijdig full colour" color_space="CMYK" collate="" facing_print="" page_order="" divider_sheet=""/>
newXML output:
<print duplex="yes" sides_printed="Hooray" sides_printed_text="dubbelzijdig full colour" color_space="CMYK" collate="" facing_print="" page_order="" divider_sheet=""/>
sander
Post by sander » Wed Jan 20, 2016 3:06 pm
If you have the scripting module, the sky is the limit :D
Good to know it helped you out!
Dave23
Post by Dave23 » Tue Jan 29, 2019 1:50 pm
Hi all,
How would this particular script work with multiple values?
	// Read properties
	var oldValue2 = s.getPropertyValue('oldValue2');
	var newValue2 = s.getPropertyValue('newValue2');
	// Create new XML
	// Replace stuff
	// Write new XML
Zoranj
Post by Zoranj » Tue Jan 29, 2019 3:02 pm
It works fine but limit is 3 values to replace for some reason.
If you add 4th, it stops working.
You could daisy chain and add script as many times as you want, times 3 values.
Dave23
Post by Dave23 » Tue Jan 29, 2019 3:14 pm
Hi zoranj
I've tried it with two using the script below, but that doesn't seem to work. It only takes into account the first value change.
Do i not need to amend this part of the code as well?
Zoranj
Post by Zoranj » Tue Jan 29, 2019 8:20 pm
Yes
var newXMLcontent = oldXML.replace(oldValue1,newValue1).replace(oldValue2,newValue2);
