I've got a bit of weird one.
It used to happen maybe once a year but over the past few weeks it seems to becoming a daily experience.
For some reason Switch will just stop doing...anything! I don't get any error messages, but if I look at a flow there will be files in it not moving.
The only way to get things moving again seem to be by restarting the whole server which is undesirable.
Sorry for being vague but there really ins't anything much to go on that I can see.
Has anyone experience this? Does anyone have any ideas for where I can look/what I can try to diagnose the issue?
Switch Not Processing
Re: Switch Not Processing
We've experienced the same thing. We "solved" it by setting our Switch server to restart every day automatically.
Do you have anything particularly clever setup in regards to stop processing, start processing etc. or are you just doing a standard system reboot?
I don't know whether it's correct or not but it was instilled in me while learning Switch that you should always stop processing before restarting the server.
I'm pretty sure this cron line is all we do (this probably isn't recommended but it solves this problem and unmounted folders not remounting properly):
59 23 * * * /sbin/shutdown -r +1;
I wish I knew what caused it. I thought that it was particularly high yield of files but sometimes that isn't the case.
Interestingly Pitstop Server also seems to stop processing files when it happens.
gabrielp wrote:We've experienced the same thing. We "solved" it by setting our Switch server to restart every day automatically.
Can you tell some more how you do this? I feel that we also have some strange 'hold ups' that only solves with a restart.gabrielp wrote:I'm pretty sure this cron line is all we do (this probably isn't recommended but it solves this problem and unmounted folders not remounting properly):
Between jobs!
Can you report the issue to Enfocus Support? This way we can check what causes it and make search for a fix in the next version. Depending on what causes it we might even find a workaround in the current version.
You can report it via the Support Portal:
http://enfocus.com/supportportal
Please provide as much information as you can (exact Switch version, OS version, exported Switch messages, ...)
On OSX, you can use cron (crontab -e). The line you add to your crontab is the code I included above. I would do a little bit of reading on cron before doing this. If you're running Switch on a PC, you have to use something else other than cron.lombert wrote: Can you tell some more how you do this? I feel that we also have some strange 'hold ups' that only solves with a restart.
