Extracting data from xml
LasseThid
Post by LasseThid »
I'm working on a flow that creates impositions using Phoenix.
As part of the output I can get an xml file. The xml file has information on all products that is part of this particular imposition.
Is it possible to somehow filter the xml file and only keep the job id (P107586_500.PDF in this case) and the names of all products?
The number of products in the xml will vary with every imposition made.
<job>
   <id>P107586_500.PDF</id>
   <name></name>
   <contact></contact>
   <phone></phone>
   <client></client>
   <notes></notes>
   <default-bleed>5mm</default-bleed>
   <units>mm</units>
   <run-length>53</run-length>
   <press-minutes>47</press-minutes>
   <plate-cost>0.0</plate-cost>
   <stock-cost>4849.6650390625</stock-cost>
   <press-cost>1175.0</press-cost>
   <die-cost>0.0</die-cost>
   <total-cost>6024.6650390625</total-cost>
   <waste>0.34245550632476807</waste>
   <sheet-usage>0.6751038432121277</sheet-usage>
   <underrun>0.0</underrun>
   <overrun>0.044802866876125336</overrun>
   <layout-count>1</layout-count>
   <layouts>
      <layout>
         <index>1</index>
         <name>Layout 1</name>
         <workstyle>FlatWork</workstyle>
         <plates>4</plates>
         <product-count>3</product-count>
         <tool-stats>
            <categories>
               <category>
                  <name>Cut</name>
                  <length>17756.4604mm</length>
               </category>
               <category>
                  <name>Crease</name>
                  <length>0mm</length>
               </category>
            </categories>
         </tool-stats>
         <priority-stats>
            <priority-stat>
               <priority>1</priority>
               <sheet-usage>0.67510384</sheet-usage>
            </priority-stat>
         </priority-stats>
         <surfaces>
            <surface>
               <side>Front</side>
               <press>
                  <name>Plano Skärbord</name>
                  <id>9c8883a0-5391-4fd9-85fc-81f4de7e976d</id>
               </press>
               <stock>
                  <name>Kanalplast</name>
                  <id>38fba052-222f-44bc-b3e1-38c800a8168c</id>
               </stock>
               <grade>
                  <name>1780 gsm</name>
                  <id>f08a4792-791a-4736-aec5-bbc3aae2c5b4</id>
               </grade>
               <sheet>
                  <name>1600 x 1780mm Long</name>
                  <id>08e98c5f-a17c-42e0-a244-b629e06b975e</id>
                  <width>1600mm</width>
                  <height>1780mm</height>
               </sheet>
               <inks>
                  <ink>
                     <name>Black</name>
                     <separation>false</separation>
                     <type>normal</type>
                  </ink>
                  <ink>
                     <name>Cyan</name>
                     <type>normal</type>
                  </ink>
                  <ink>
                     <name>Magenta</name>
                     <type>normal</type>
                  </ink>
                  <ink>
                     <name>Yellow</name>
                     <type>normal</type>
                  </ink>
                  <ink>
                     <name>Cut</name>
                     <separation>true</separation>
                     <type>cut</type>
                  </ink>
               </inks>
            </surface>
         </surfaces>
      </layout>
   </layouts>
   <products>
      <product>
         <name>P107586_400.PDF</name>
         <index>1</index>
         <ordered>150</ordered>
         <die-source>_11F7C_P107586_400.PDF</die-source>
         <die-path>C:/Users/Admin/AppData/Local/Temp/phoenix-c9ce838b-cd34-4f72-8621-f623c3e516db/P107586_500PDF-4116310353162221012/upload/1/_11F7C_P107586_400.PDF</die-path>
         <stock>Kanalplast</stock>
         <grade>1780 gsm</grade>
         <grain>None</grain>
         <width>399.5282mm</width>
         <height>463.6602mm</height>
         <spacing-type>Uniform</spacing-type>
         <group>Kanalplast_1780 gsm</group>
         <rotation>Orthogonal</rotation>
         <templates/>
         <placed>3</placed>
         <total>159</total>
         <overrun>9</overrun>
         <layouts>
            <layout index="1" placed="3"/>
         </layouts>
      </product>
      <product>
         <name>P107587_300.PDF</name>
         <index>2</index>
         <ordered>39</ordered>
         <die-source>_11F7E_P107586_300.PDF</die-source>
         <die-path>C:/Users/Admin/AppData/Local/Temp/phoenix-c9ce838b-cd34-4f72-8621-f623c3e516db/P107586_500PDF-4116310353162221012/upload/2/_11F7E_P107586_300.PDF</die-path>
         <grain>None</grain>
         <width>299.4127mm</width>
         <height>347.5097mm</height>
         <templates/>
         <placed>1</placed>
         <total>53</total>
         <overrun>14</overrun>
         <layouts>
            <layout index="1" placed="1"/>
         </layouts>
      </product>
      <product>
         <name>P107588s_500.PDF</name>
         <index>3</index>
         <ordered>369</ordered>
         <die-source>_11F7A_P107586_500.PDF</die-source>
         <die-path>C:/Users/Admin/AppData/Local/Temp/phoenix-c9ce838b-cd34-4f72-8621-f623c3e516db/P107586_500PDF-4116310353162221012/upload/3/_11F7A_P107586_500.PDF</die-path>
         <grain>None</grain>
         <width>499.413mm</width>
         <height>579.5782mm</height>
         <templates/>
         <placed>7</placed>
         <total>371</total>
         <overrun>2</overrun>
         <layouts>
            <layout index="1" placed="7"/>
         </layouts>
      </product>
   </products>
</job>
Lasse
cstevens
Re: Extracting data from xml
Post by cstevens »
How do you want the information saved? Do you want a new XML file with just that information in it, or are you trying to pull it into a script for use elsewhere?
If you want a new XML file then an xsl transform is probably the easiest option.
If the later then you can do something like this:
	var xmlDoc = new Document(job.getPath());
	var jobId = xmlDoc.evalToString("//job/id");
	s.log(1, "JobID is: " + jobId);
	var productNames = xmlDoc.evalToNodes("//job/products/product/name");
	for(var i=0; i<productNames.length; i++){
		s.log(1, "ProductName " + i + " is: " + productNames.at(i).evalToString("./text()"));
cstevens
Post by cstevens »
It would probably be easier to add product name values to an array like this:
	var namesArray = [];
		//s.log(1, "ProductName " + i + " is: " + productNames.at(i).evalToString("./text()"));
		namesArray.push(productNames.at(i).evalToString("./text()"));
	s.log(1, "List of ProductNames is: " + namesArray.toString());
sander
Post by sander »
cstevens wrote:If you want a new XML file then an xsl transform is probably the easiest option.
If you might need this, Lars, it’s already done here: viewtopic.php?f=12&t=1201&p=4080&hilit=Xslt+split#p4080
I’m using the Saxon configurator now to do the same. If you want I’ll post next monday.
LasseThid
Post by LasseThid »
The flow will make ganging impositions for our large format digital printers and I need to somehow let the printer operators know which jobs are in which file. Phoenix is currently set up to use the name of the first file for the imposed file, but as it's a ganging imposition there may be several orders in one imposition.
When exporting the imposed pdf from Phoenix I can either create a report (PDF) or an xml file like the one I posted.
My first idea was to print the report on paper and give it to the printer operator together with the work order(s), but the large format print manager don't think it will work very well, so he would like to have all order numbers in the file name instead. That way they can find the job by just searching for the order number. The biggest problem with this of course is if you have many different orders on one sheet, but he figures we will have no more than two or three orders on the same sheet.
If I can filter the xml file to only include only the different order numbers I might be able to use that xml to send one or more e-mail to our planning tool and include the information as a note in the planned job. I.e. this job is in the file named XXXXXXXXX.pdf. That way it would be easy for the print operator to find which file(s) to print.
Worst case the prepress operators will have to sort the incoming jobs by stock and cutting method and then use the reports to add this information in the planning tool.
LasseThid
Post by LasseThid »
I've tried to create an XSLT file using copy/paste and google, but when I put this file in an online transformer along with the xml I get an error saying "The element type "xsl:template" must be terminated by the matching end-tag "</xsl:template>"."
As far as I can see it's terminated correctly, but on the other hand I would understand almost as much if I tried to read something in mandarine... :lol:
<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
	xmlns:xs="http://www.w3.org/2001/XMLSchema"
        exclude-result-prefixes="xs"
        version="1.0">
	<xsl:output method="text"/>
	<xsl:template match="/">
		<xsl:value-of select="//job/id"/>
		<xsl:text>;</xsl:text>
		<xsl:for-each select="product"/>
			<xsl:value-of select="//products/product/name"/>
		</xsl:for-each>
	</xsl:template>
</xsl:stylesheet>
cstevens
Post by cstevens »
You've got an extra closing tag at the end of your for-each opening tag:
should be:
<xsl:for-each select="product">
If you get rid of that it should be valid.
