Hi!
Im building a flow where the app "Inject Lite" fetch a file from a folder based on data from an incoming XML.
My problem is that Inject Lite place the file into a folder. Does anybody know how to avoid this?
I know I should know how to solve this by now, but apparently Im not as smart as I thought I were.
Thanks!
//Anders
Inject Lite place files in folders
Re: Inject Lite place files in folders
Could you share the flow properties of the inject lite configurator and an example of what the output looks like?
Hi Gabriel,
Sure!
↑Inject Lite
Type Inject Lite
Description
Trigger Incoming job
Target Specific job
Job path //192.168.163.188/public/it/xml/[Metadata.Text:Path="/root/order/ordertag",Dataset="Xml",Model="XML"]/tryck
Inject type Inject (read-only)
Name job after Injection job
Here is a screenshot of the output folder. As you can see the file is placed inside a subfolder which I don't want.
https://ibb.co/fR8Ctc
Sure!
↑Inject Lite
Type Inject Lite
Description
Target Specific job
