Do you know if there is a way to sort PDFs with/without annotations ? I'm searching how I could have in a output folder only PDF with annotations, and in another output folder without annotations.
Think it could be done, right ?
Thanks in advance,
Christian
Sort PDF with or without annotations
Re: Sort PDF with or without annotations
In PitStop Server you can make a preflight profile which will trigger an error when an annotation is found. Using that preflight profile in the PitStop Server configurator you can then sort out pdf files with and without annotations.
That's a good idea, effectively it works well with it !
Many thanks for this tip !
