There are no sample jobs in the flow
jmatheny
Post by jmatheny »
I am using the mail receive and TXT pickup to try and extract information from incoming emails. This means I have a bunch of .txt files in my flow with data-sets assigned to them. However, when I try to build a location path I get "There are no sample jobs in flow" but I have plenty of jobs. This happens with Inspect Jobs as well. Is it because they are text files? Or am I missing something?
Thank you in advance for any advice.
Re: There are no sample jobs in the flow
They are only visible if they are staying in the flow. If they have reached a final folder they don't have any metadata in them.
Insert a folder before the last folder and put the connection between them on hold and you will see your files in the variable setup.
jmatheny
Post by jmatheny »
Thank you!
jmatheny
Post by jmatheny »
Thank you!
