We try to made a flow with images in subfolders but the flow did'nt work.
We have input hotfolder : SWITCH/FLOW-01/IN
In this hotfolder, we have to put folders with images : FolderA, FolderB, FolderC
The action is to made lowsres and highres images into theses folders.
Images in LowRes in a subfoler LR
Images in HighRes in a subfolder HR
For now we have a flow that do it when we sent images directly in the input folder. It made results in output folders HR and LR.
Now, we want to put folders in the input folder, and then have the images treated in the output folders with the same input folders FolderA, FolderB, FolderC, with inside the result in the subfolder HR and LR
(Because in the FolderA, FolderB, FolderC, we have images with the same name, but images are differents, so we need that output have the same subfolders to preserve hierarchy.)
When we try to do it, we have a mistake with output, we didn't know how to setup submit hierarchy....
Many Thanks !
Submit Hierarchy SubFolders
Re: Submit Hierarchy SubFolders
My recommendation if you want to learn how Hierarchy works in Switch is to watch excellent workshop from September 2017.
It explains in detail how it works, it is resource I refer to often when I am building something with hierarchy.
OK many thanks, I'm looking for this workshop I didn't see.
Thanks for your prompt answer,
Christian
Christian
Funny, I can't find it online either??
I can upload it for you, I just want to make sure it is ok to do so, Enfocus?
Zoranj,
Found what's going wrong with my flow, I miss to configure step with "Build new path" to create my "LR" and "HR" folders, and then forget to choose "strip unique name : yes" and now all is going fine !
Best Regards,
Christian
Best Regards,
Christian
