I have a flow where I need to pick up files from an archive and assemble them in the order they are in the csv file provided by the customer.
I get the position from the name of the xml created by CSV2XML and add that to the file name by adding it as a suffix to the file name.
However, when I do the Merge PDF the page order is 10, 11, 12, 13, 14, 15, 16, 1, 2, 3, 4, 5, 6, 7, 8 and finally 9. I'm guessing this is due to the fact that the length of the suffix is 1 for some files and 2 for some files. Is it possible to somehow add leading zeros to the suffix either when I place it in the Private data or when I add it as a suffix?
Thanks in advance
Add fixed length numerical value as Private Data or suffix
Re: Add fixed length numerical value as Private Data or suffix
Search & Replace -> RegEx ??
Search ^(\d{1})(_)(.*)
replace 0\1\2\3 ??
replace 0\1\2\3 ??
Thanks Arthur.
Will that work with a file name looking like this?
P123456_1_flying-elephant-100x70-1.pdf
I solved it by using three different Rename job and branching them higher than 99, lower than 100 AND higher than 9 and lower then 10 and then adding no, one or two zeros before the position number. However the Merge PDF still insists on putting the pages in the same order as before...
So from this string example - P123456_1_flying-elephant-100x70-1.pdf
Which element / block indicates the single digit number, or double digit number or - if applicable (a 3digit) that requires changing ??
It's the last number that is the suffix.
I'd like the file name to be P123456_1_flying-elephant-100x70-001.pdf
As I'm having problems getting the files merged in the correct order it may be that I have to have the file name with the position number after the ourder number instead, i.e. P123456_001_flying-elephant-100x70.pdf. I just need to figure the Merge PDF out first...
Ahhh I see.
So in order to get that you'd need the following Regex:
^(.*)(-)(\d{1})(.[^.]+)$
and the substitution would be:
\1\20\3\4
where the 0 between \2 and \3 makes it 2-digit.
If 3 digits needed, then two 0s need to be put in place.
If you had 2 digits there, then the regex would be: ^(.*)(-)(\d{2})(.[^.]+)$
and subsequently you need only one 0 as in the first substitution.
Reference - https://regex101.com/r/ukbbaM/1
\1\20\3\4
Thanks Arthur.
Since I would need three different Rename job anyways I might as well stay with the ones I set up.
In order to get Merge PDF to place the pdf's in the correct order I decided to change the file names to be only order number followed by position. The file names are irrelevant anyway. Now I'm just waiting to see if Phoenix will do it's job properly...
