XML Pickup for Multiple Values
matt.baile
Post by matt.baile »
Hello. I'm doing an XML pickup and hoping to use the values from the pickup to route orders a certain way. What I have is a structure that looks like this:
<ORDER_ITEMS>
     <ORDER_ITEM>
          <ORDER_QUANTITY></ORDER_QUANTITY>
     </ORDER_ITEM>
</ORDER_ITEMS>
I could have multiple <ORDER_ITEM> entries or just one, each file will be different. What I need to do is look at each of the quantity fields and find out of there are any that are over 200 copies or possibly say are there any >=200 AND <=25, or something like that. I've only been able to get something like this, where my <ORDER_QUANTITY> is whatever number I highlight. Is there a way to get all of the entries, like an array or nested values?
[Metadata.Text:Path="/TOP/ORDERS/ORDER/ORDER_ITEMS/ORDER_ITEM[1]/ORDER_QUANTITY",Dataset="Xml",Model="XML"]
cstevens
Re: XML Pickup for Multiple Values
Post by cstevens »
I think this is a limitation with the XML Pickup module. Expressions like this can only resolve to a single value, so when an XPath resolves to multiple values it either errors or returns the first value in the list.
I think you'll need to use a script expression that evaluates to a node list and then parse through the result set.
I think there's a thread on here about using variables in expressions like this. If you could use a variable in place of the 1 you might be able to "loop" a file through the XML Pickup module incrementing that value each time, but that seems like it could cause other issues.
Malcolm Mackenzie
Post by Malcolm Mackenzie »
https://www.enfocus.com/en/appstore/pro ... l-repeater
can split the xml to for each entry for sorting, not sure if it will deliver what you want.
Malcolm Mackenzie
You can also split the XML to single XML-files for each item with XSLT and Saxon configurator
r.zegwaard
Post by r.zegwaard »
You can quite easy sort the files based on the number of nodes with a quantity >= 250 or <=25
I've created a flow like this:
The condition for routing to folder 3 or 4 is:
[Metadata.Integer:Path="count(//ORDER_ITEM[ORDER_QUANTITY >= 250 or ORDER_QUANTITY <=25])",Dataset="Xml",Model="XML"]
matt.baile
I think the XML repeater may be an option, but I'm not able to purchase anything from the app store at this point.
@r.zegwaard - Your idea seems to be correct, but is that looking at the total number of nodes, or looking at the value in the ORDER_QUANTITY itself? I'm not so much concerned with how many nodes appear, just the values that are in those nodes.
r.zegwaard
It counts the the number of order_items for which the quantity is >= 200 or quantity is <= 25
If the this counted value is > 0 the job goes that direction.
Arthur
Post by Arthur »
Could I add a question here regarding this method, which I am trying to utilise for something similar ??
XML structure is as per the following:
-<csv>
-<row>
<col name="FileName">Some Filename</col>
<col name="FileSize in KB">12345</col>
</row>
</csv>
Looking to get the number of nodes for the 'FileSize in KB' equal to 0.
For this I am thinking of using the following XPath expression:
count(//col[@name='FileSize in KB'=0])
But it returns total number of nodes @name='FileSize in KB' rather than actually count those which value is 0.
If there is a different way of stating this equation of 'equal 0' - could someone point me in the right direction pls.
Losing patience now :)
--- EDIT ----
OK, I've got it. ... But .... I do not understand it. Could someone wise explain why in order to get the total number of /col nodes with a @name='FileSize in KB' it requires that node name identifier to be present, but to count those that have 0 value it works with the following:
count(//col[.='0']) and does not require the name of the /col to be present???
I see no logic here :(
