I've got a simple question about the "Split PDF" -Element.
Is it possible to set the index with a leading zero, if the number of pages is smaller than 10 pages?
E.g. filename.pdf -> filename_1.pdf if the document has only 4 pages, but it should be filename_01.pdf
Or do I have to write a script for that?
Thanks for your help!
Michael
Split PDF Filename
- TOP CONTRIBUTOR
Split PDF Filename
Use a Rename Job element after the splitting.
Split PDF Filename
Thanks,
I've used the Regex Search
_(?=d{1,1}$)
and Replace by
_0
in the rename element.
But it would be nice to have an option in the PDF Splitter for that...
Michael
_(?=d{1,1}$)
and Replace by
_0
Michael
