rename elements with switch counter in subfolder
ChritianK
Post by ChritianK »
We wants to rename files/jobs in subfolders but the result is not what we attempt :
- if I have 2 subfolders A and B with each 10 elements, folder A and B drop into input folder at the same time with rename
- Folder A have 1 to 10
- Folder B have 11 to 21
But what we want is :
- Folder B have 1 to 10
Do you know how could we do it ?
Thanks,
Christian
saitok
Re: rename elements with switch counter in subfolder
Post by saitok »
Which Flow element do you use?
I guess you can do it with "Sort files in job".
Before that, you have to use "Job dismantler" to pick up the sub folders.
Regards,
