Rename job issue
Posted: Wed Jul 10, 2019 3:44 pm
I have a couple of flows where I use GMG Color Server for color conversion. For some reason the jobs will get stuck at the GMG Color Server configurator if the file name contains the nordic characters å, ä or ö, so in order to make sure the files doesn't contain these characters once they reach the GMG configurator I use a number of Rename jobs to fix the issue.
If I submit one file at a time this works perfectly.
If I submit more than one file at a time and send them as Separate jobs the flow will rename the files correctly.
If I submit more than one file at a time and send them as One job the flow will not rename the files, even though I use a Job dismantler to make sure the files are not in a folder once they reach the Rename Job elements.
If I submit the job as a folder the flow will not rename the files correctly.
Any ideas at to why the Rename job will not work if the files were submitted as a folder? (Switch 2019 Spring Edition)
