Read OutputIntent as String
Frank0
Post by Frank0 »
can we use Switch to read/check the output intent of a PDF-X file with a string (like a creator or the applikation), is this possible?
Many thanks
Frank
Malcolm Mackenzie
Re: Read OutputIntent as String
Post by Malcolm Mackenzie »
Yes.
Make a new action.
Under color add Check Output Intent with your reference.
Padawan
Post by Padawan »
I'm not sure, but I think the name of the output intent is stored somewhere in the internal Xmp metadata of the PDF file. If you have the metadata module, then you can access the Xmp metadata via Switch variables.
jan_suhr
Post by jan_suhr »
Acrobat XMP-data that is visible in Switch doesn't contain the Output Intent.
Best way is to use Apago PDF Spy, it will list the output intent in a Dataset
Screenshot 2019-07-18 20.18.51.png (91.29 KiB) Viewed 4515 times
Jan Suhr
Color Consult AB
Sweden
Check out my apps
