Execute Command and ImageMagick
numnational
Post by numnational »
Hi all, sorry i'm starting with Execute Command and ImageMagick.
Here is my request.
I have 2 jpg file, 1 file for the Left on file for the Right (R & L). I want to have only one jpg file with the 2 pages, a montage of them.
I use ImageMagick on my local computer with this command on the Terminal and it work like i want : montage -geometry +0,1 '*.jpg' FinalMontage.jpg
See my example here :
https://www.dropbox.com/s/fsdhlmr0u5ek3 ... 1.png?dl=0
When i try to do this on the Switch server it doesn't work...
Here is my argument on the Execute command tools :
Execution mode : Concurent
Command or path : D:/Program Files/ImageMagick-7.0.8-Q16/magick.exe
Arguments : montage -geometry +0,1 "%1" "%2"
Output : File at pat
Copy input job : No
Output extension : Automatic
Fail if exit code is : Disregard exit code
Dont understand how i must change to work to have my final montage.
ImageMagick is correctly installed beacause i make another tools just to test and it work : convert -resize 5% "%1" "%2"
If you have a idea... Thanks.
jan_suhr
Re: Execute Command and ImageMagick
Post by jan_suhr »
You probably have to create a .BAT-file to run that in imageMagick.
Then you tell Execute Command to run that .BAT-file.
You can use my app "Execute Command Friend" to easily create the .BAT-file and use Switch variables in a very easy way.
https://www.enfocus.com/en/appstore/pro ... and-friend
Jan Suhr
Color Consult AB
Sweden
Check out my apps
numnational
Thanks for your answer Jan, but i'm not enought ok with script or .bat file... don't understand the rule to crate my job... :roll:
Arthur
Post by Arthur »
Try to modify your arguments for %1 & %2 with fixed paths and switch arguments if needs be.
jan_suhr
Post by jan_suhr »
Your .BAT could be something like this. I haven't tried it myself but it gives a clue on what you should try.
set inputfile=%1
set outputfile=%2
magick.exe montage -geometry +0,1 %inputfile %outputfile
You could try the .BAT-file with CMD.EXE and change the file variables to real paths and test if it will run.
Jan Suhr
Color Consult AB
Sweden
Check out my apps
numnational
Hi here is my final command, working perfectly thanks to Enfocus Support.
montage -geometry +0,1 "%1\[Job.NestedName:Index='2',After=' ']" "%1\[Job.NestedName:Index='3',After=' ']" "%2"
ChritianK
Post by ChritianK »
Have a similar issue with montage and to made contact sheet with several images :
This command I test in a .bat file works successfully :
"C:\Program Files\ImageMagick\magick.exe" montage -units PixelsPerInch "path\TEST\*.jpg" -tile 3x2 -geometry 827x1772+0+0 -density 300 "path\TEST\result\contact_sheet.jpg"
- Made a flow with Assemble Job in order to have a folder with all my images in it to made the contact sheet.
Then I try this Execute command :
Type Execute command
Description
Execution mode Serialized
Command or path C:/Program Files/ImageMagick/magick.exe
Arguments montage "%1"-units PixelsPerInch -tile 3x2 -geometry 827x1772+0+0 -density 300 "%2"
Output Result in folder
Copy input job Yes
Fail if exit code is Nonzero
Fail if stdout contains
Fail if stderr contains
But it failed, have this :
"2019-11-15 11:56:00","error","Execute command","CONTACT_SHEET","contact sheet","07MXT","planche","Job ''_07MXT_planche'' was moved from folder ''C:/Users/Administrateur/AppData/Roaming/Enfocus/Switch Server/backing/CONTACT_SHEET/automanaged/Folder 51'' to the problem jobs folder. Reason: see previous log message(s)"
"2019-11-15 11:56:00","error","Execute command","CONTACT_SHEET","contact sheet","07MXT","planche","Job failed because outcode is nonzero, outcode = [1]"
"2019-11-15 11:56:00","debug","Execute command","CONTACT_SHEET","contact sheet","07MXT","planche","stderr: montage: UnableToOpenConfigureFile `magic.xml'' @ warning/configure.c/GetConfigureOptions/714.; montage: UnableToOpenBlob ''C:\Users\Administrateur\AppData\Roaming\Enfocus\Switch Server\temp\169\ScriptElement\696\12\planche'': Permission denied @ error/blob.c/OpenBlob/3489.; montage: UnableToOpenConfigureFile `delegates.xml'' @ warning/configure.c/GetConfigureOptions/714.; montage: UnableToOpenBlob ''C:\Users\Administrateur\AppData\Roaming\Enfocus\Switch Server\temp\169\ScriptElement\696\12\planche'': Permission denied @ error/blob.c/OpenBlob/3489.; montage: NoDecodeDelegateForThisImageFormat `'' @ error/constitute.c/ReadImage/556.; montage: MissingAnImageFilename `C:\Users\Administrateur\AppData\Roaming\Enfocus\Switch Server\temp\169\ScriptElement\696\10\ExecuteComandResult\planche.jpg'' @ error/montage.c/MontageImageCommand/1777. »
It seem permission denied issue or is there another problem I didn't see ?
Thx in advance if anybody have ideas :-)
jan_suhr
Post by jan_suhr »
Have you tried this:
Arguments montage -units PixelsPerInch "%1" -tile 3x2 -geometry 827x1772+0+0 -density 300 "%2"
Jan Suhr
Color Consult AB
Sweden
Check out my apps
ChritianK
Post by ChritianK »
Thanks for answering, I try it yes
but have the same error....
stderr: montage: UnableToOpenConfigureFile `magic.xml' @ warning/configure.c/GetConfigureOptions/714.; montage: UnableToOpenBlob 'C:\Users\Administrateur\AppData\Roaming\Enfocus\Switch Server\temp\169\ScriptElement\696\15\planche': Permission denied @ error/blob.c/OpenBlob/3489.; montage: UnableToOpenConfigureFile `delegates.xml' @ warning/configure.c/GetConfigureOptions/714.; montage: UnableToOpenBlob 'C:\Users\Administrateur\AppData\Roaming\Enfocus\Switch Server\temp\169\ScriptElement\696\15\planche': Permission denied @ error/blob.c/OpenBlob/3489.; montage: NoDecodeDelegateForThisImageFormat `' @ error/constitute.c/ReadImage/556.; montage: MissingAnImageFilename `C:\Users\Administrateur\AppData\Roaming\Enfocus\Switch Server\temp\169\ScriptElement\696\13\ExecuteComandResult\planche.jpg' @ error/montage.c/MontageImageCommand/1777.
ChritianK
Post by ChritianK »
Find solution with help from support, that give me the way to understand what's wrong ! 8-)
