Send files one at a time from a folder
LasseThid
Post by LasseThid »
Is it possible to get the Hold job configurator or any other configurator to send one file every n seconds?
The Delay function will hold the files for a certain time and then send them to the next folder/configurator, but that can mean that five or more files are sent thru at the same time. If possible I'd like to send a file every 10-15 seconds.
Zoranj
Re: Send files one at a time from a folder
Post by Zoranj »
Use Hold jobs configurator but instead of setting it up, setup outgoing connection.
In the bottom of the properties you will find "Space jobs apart" option.
Set it to 10 seconds, or whatever and off you go.
Screen Shot 2019-10-10 at 4.36.05 PM.png (21.03 KiB) Viewed 3542 times
LasseThid
Post by LasseThid »
Thanks Zoran!
Much appreciated.
