Excuse the simple question, hopefully the answer is just as simple:
I've installed the PDF Review web server on an existing server, and it looks that the PDF review server is running on port 8080. I already have services running on that port. Is there a way to change the port that PDF review is using?
Thanks!
PDF Review - Changing Service port
Re: PDF Review - Changing Service port
Yes you can set which ever port you like in the Admin section of the PDF Review page.
your-ip.com:8080/admin give you access to it.
https://www.enfocus.com/manuals/UserGui ... about.html
