Submit point metadata, field list value
Posted: Thu Jan 09, 2020 10:10 am
Hi. Having a bit of a problem.
I have submit point in switch, that has metadata field with "Dropdown List" and there are two more metadata fields that depends on answer to the first one. Basically, here's a rough example: http://prntscr.com/ql788m and http://prntscr.com/ql780u
Now, all is good and fine until I have to actually use this metadata: http://prntscr.com/ql7fq9
As you can see, both of them have same path, is there any way to distinguish it one from another? Since if I use one path somewhere, it won't matter what user chooses in submit point since one of those will appear there anyways. Hopefully this makes sense. Thanks.
