Hi, I need to get a specific part of a filename (NameProper) as a variable in a Switch flow.
This is my NameProper: SOR808080_QP - @ 1, 2 (This is the string I want)_1010.abc
And I want: This is the string I want
My regex is (in the Search-field in Variables tab): (?<=\()(.*?)(?=\))
When I try it on https://regex101.com it works good, but in Switch it donät give me any result at all. Any suggestions how to solve it?
Trying to get a specific part of NameProper with regex
- magnussandstrom
- magnussandstrom
Re: Trying to get a specific part of NameProper with regex
I noticed that I could use the Before and After in this case, but It would be good to know why the regular expression did not work.
That's because of "Note: Positive and negative lookbehind are currently not supported." in here: https://www.enfocus.com/manuals/UserGui ... sions.htmlmagnussandstrom wrote: ↑Wed Jun 09, 2021 9:59 pm I noticed that I could use the Before and After in this case, but It would be good to know why the regular expression did not work.
- magnussandstrom
Ok I see, that explains it.
