Scan barcodes (QR) and output as textfile
- magnussandstrom
Hi, I would like to build a flow thats scan QR codes and outputs a textfile with the barcode information. Is it possible to use Switch and Pitstop for this? Any suggestions?
- JimmyHartington
Re: Scan barcodes (QR) and output as textfile
Hi Magnus
I will recommend looking at this tool:
http://zbar.sourceforge.net
which you should be able to integrate with Switch.
I have had some issues using Pitstops scan QR-code function. It did not catch all.
Using on this file https://d.pr/f/fw7Mat
returns
Using
zbarimg
returns
QR-Code:https://www.skabertrang.dk
scanned 1 barcode symbols from 4 images in 0,8 seconds
There's an action list element in PitStop called "check barcodes" (or something along those lines, my installation is in German) where you can check for a QR code and its contents. You could then use the free app "Create text file" to get the contents of the QR codes stored in the Log metadata and create a textfile with the barcode information. I've attached a screenshot of the flow. I can send you the flow, just shoot me a message on here with your email .
- Bildschirmfoto 2022-04-04 um 11.22.30.png (66.98 KiB) Viewed 15982 times
Did you report those, Jimmy? And Magnus, the PitStop method as described by nna is still worth trying because PitStop certainly does not miss all QR codes. Codes that are missed could be due to rotation (there is an option for taking that into account or not), or to bad colors, and that may not apply in your case.JimmyHartington wrote: ↑Mon Apr 04, 2022 11:22 am I have had some issues using Pitstops scan QR-code function. It did not catch all.
- JimmyHartington
HI Freddy
Yes, I did report it and it should be logged for development to look at. (Case Number ENF-00176660)
The problem was with this simple file: https://d.pr/f/9TVKMs
Where no QR-codes a read with default settings.
zbar reads all 5 in 0.46 seconds.
Hi, is there any news on this? Im looking for a way to read very basic datamatrix codes and the PitStop-Action doesn't catch these at all – in fact, it doesn't work on most of my test files.
- JimmyHartington
I did report it to development.noblekeon wrote: ↑Tue Sep 26, 2023 11:56 amIf so, Jimmy, did you report them? It's still a good idea to give nna's PitStop technique a shot, Magnus, as it doesn't miss all QR codes. Codes may be missed for various reasons, including rotation (which can be taken into account or not) or poor color contrast, neither of which may be relevant to your situation.JimmyHartington wrote: ↑Mon Apr 04, 2022 11:22 am I have had some issues using Pitstops scan QR-code function. It did not catch all.
