JavaScript to Save as idml file in Indesign
Flow666
Post by Flow666 » Wed Jan 30, 2013 5:11 pm
I need to save some Indesign document to older versions (idml).
But i can't find any samples from javascript in combination with Switch on how to do this.
Can somebody point me to some sample files.
The manual from Switch isnt very helpfull.
TOP CONTRIBUTOR
Post by dkelly » Wed Jan 30, 2013 6:27 pm
You could try something like:
var regex = /.indd/gi
var fileName = app.activeDocument.fullName.replace(regex, ".idml");
app.activeDocument.save(File(fileName), true);
Flow666
Post by Flow666 » Wed Jan 30, 2013 9:32 pm
I am using the Indesign Configurator to process my jobs.
The settings i use are:
Open = Automatic
Command = None
Save = Use Script
Do i have to use the $code instead of app.activeDocument to get it working?
Or do i use the code in SwitchScripter?
I am getting errors that no documents are open.
Post by freddyp » Thu Jan 31, 2013 3:59 pm
Yes, you do and you have to fill out the $outfiles array so Switch knows what output files your script created. See the Switch help: Introduction - Advanced topics for designing flows -Javascript for applications.
Here is the code:
var tempDir = "/Users/fp/Desktop/";
var fileName = $doc.name.replace(".indd",".idml");
$doc.exportFile("InDesign Markup (IDML)",tempDir+fileName);
$outfiles = []
$outfiles.push(tempDir+fileName);
$doc.close;
Switch will automatically remove the temporary file, by the way.
Flow666
Post by Flow666 » Thu Jan 31, 2013 4:45 pm
Thanks dkelly and freddyp. It works!!
I found that in my older script the documents where still open, but not visable.
With the $doc and $outfiles it works, thanks a lot.
TLagueux
Re: JavaScript to Save as idml file in Indesign
Post by TLagueux » Wed Mar 07, 2018 3:20 pm
I was using this script but it does not work anymore since I installed the last update.
Any idea why?
Regards,
Thierry
Padawan
Post by Padawan » Mon Mar 12, 2018 2:44 pm
Hi THierry,
By update you mean an update of InDesign? If so, which version are you running now?
Do you get an error in the messages?
Corporate films
Post by Corporate films » Tue Apr 10, 2018 10:24 am
Hey there
I am using this InDesign for saving my JavaScript but not getting good results.
Please suggest what to do.
For reference http://www.corporatefilmsmumbai.com/gallery.html
