TIL: mapping multiple Statement() against one DataSource() is a bad idea
Posted: Fri Dec 18, 2015 10:07 am
just FYI, there obviously is a difference between:
and
Notice that every Statement has its own DataSource. The behaviour is totally dependent of the ODBC driver in use. The first example worked fine on a MAC with the ActualODBC package against a MS SQL server, it failed to work on a Win10 machine with MS ODBC drivers: the second Statement.execute() always returned 0 rows.
Using multiple DataSource() fixed this, but also slowed the script down a bit... So if you hit that problem... there's a fix for that
var dbConn=new Datasource();
dbConn.connect("dsnname");
var orderSQL=new Statement(dbConn);
orderSQL.execute("SELECT id FROM orders");
while( orderSQL.isRowAvailable() )
orderSQL.fetchRow();
var orderID=orderSQL.getString(0);
var shipmentSQL=new Statement(dbConn);
shipmentSQL.execute("SELECT id FROM shipments WHERE orderid='"+orderID+"'");
while( shipmentSQL.isRowAvailable() )
shipmentSQL.fetchRow();
var shipmentID=shipmentSQL.getString(0);
var lineItemSQL=new Statement(dbConn);
lineItemSQL.execute("SELECT foo,bar,fup FROM lineitems WHERE shipmentID='"+shipmentID+"'");
// do stuff with these values
dbConn.disconnect();
var orderConn=new Datasource();
orderConn.connect("dsnname");
var shipConn=new Datasource();
shipConn.connect("dsnname");
var itemConn=new Datasource();
itemConn.connect("dsnname");
var orderSQL=new Statement(orderConn);
var shipmentSQL=new Statement(shipConn);
var lineItemSQL=new Statement(itemConn);
orderConn.disconnect();
shipConn.disconnect();
itemConn.disconnect();
