Re: switch-inject-lite
Posted: Wed Jan 10, 2018 3:51 pm
Hello Gabriel,
Is it possible to use "Assert exist" option to check if a (job)folder exists or not? A folder, not a file.
When I leave "Job extension" empty (like you can do in the classic "Inject Job" element), The trigger job doens't flow through the Inject-Lite element.
It gets stuck in the folder in front of it. You need to enter a file extension in the properties to make it go further along.
Do you have a work around for this problem?
Thanks in advance for the support!
Greetings from the Netherlands,
Mireille
Mireille
