this is what i get form my metadata log.
Switch varibale '[Metadata.TextIndexed:Path="//info",Dataset="Mail",Model="XML",Separator="<br>"]'
this gives me a list which is very cool
46278 Folder with pocket WR129238E
46279 Business Cards - 25 sets of 250 each WR129237E
46280 Letterheads WR129237E
47121 Business cards. 100 each of 9 different + 50 of another WR129170E
will it be possible to auto number the list?
1. 46278 Folder with pocket WR129238E
2. 46279 Business Cards - 25 sets of 250 each WR129237E
3. 46280 Letterheads WR129237E
4. 47121 Business cards. 100 each of 9 different + 50 of another WR129170E
PS. the number of items in the list will vary each time
Auto number a list from metadata
Re: Auto number a list from metadata
Can you give us a little more information?
It appears that the incoming job has an XML attached as metadata. You locating the individual items by splitting on "<BR>" element.
What element are you using the variable? In a script or Condition with variables?
Hi dkelly
Ok, so my plan is to mail a active job list to our customers. a simple text file picks up the xml as a dataset from our MIS, then i use that metatdata in a mailsend element.
this variable gets incorporated in the mail as a list.
Re: Auto number a list from metadata :Solution
The use of <ol></ol> html tag does the trick
what the Switch variable in the HTML mail looks like:
<ol><li>[Metadata.TextIndexed:Path="//info",Dataset="Mail",Model="XML",Separator="</li><li>"]</li></ol>
the result:
the result:
- Capture.JPG (39.21 KiB) Viewed 8286 times
