cwswitch
Posts: 101 Joined: Fri Feb 24, 2017 12:25 am
Post
by cwswitch » Sun Jan 13, 2019 11:35 pm
Can I push any error in a script to the error out connector?
Or must I have a try catch and the catch pushes the error the way I want?
If try/catch was the way, then do I copy the problem bit of code like this?
try {
problem code in its entirety even if it is several lines long;
} catch (e) {
job.sendToData( 3, job.getPath() );
Ideally -
What I'd really like is a neat way to capture any error whatsoever and have it push to Error Out
Posts: 367 Joined: Mon Jun 12, 2017 8:48 pm
Post
by Padawan » Mon Jan 14, 2019 8:39 am
Your code looks like it will work (assuming of course you have set the outgoing connection to be traffic light). Personally, I would add a line to log your exception in the Switch messages.
try {
//problem code in its entirety even if it is several lines long;
} catch (e) {
job.log(3, e);
