Make JSON empty values
Posted: Wed Jan 23, 2019 12:35 pm
Morning all,
I'm using "Make JSON" app to generate a json which i am then using to generate an order in our production environment. I am using variables from xml for the values in the json.
The problem I am having is that if one of those values is empty, the json will submit the order but in place of the empty value it will use 'undefined'.
Is there a way to remove all name/values when a value is empty?
