Need help breaking text file with multi lines into individual one line text files
Zoranj
Post by Zoranj » Thu Oct 03, 2019 9:57 pm
I hope I am explaining it right.
I have a single text file with 50 lines of text
line1
line2
line3
I want to get 50 text files with one line of text:
line1.txt
line2.txt
line3.txt
Gabriel had Javascript that does similar thing but it logs individual lines only, does not output them.
Is it possible to modify it to output text files instead?
// Helper function
	var forEach = function(array, callback){
   var currentValue, index;
   for (i = 0; i < array.length; i += 1) {
      if(typeof array[i] == "undefined"){
         currentValue = null;
      } else {
         currentValue = array[i];
      index = i;
      callback(currentValue, i, array);
	// Construct File object
	var file = new File( job.getPath() );
	/// Open file as read only
	file.open( File.ReadOnly );
	// Create an array of the lines of the file
	var file_as_array = file.readLines();
	// Close the file
	file.close();
	// Get the first line
	// var first_line = file_as_array[0]; // This is how you get the first line if you need it
	// Slice the array without the first line
	var sliced_array = file_as_array.slice(1, (file_as_array.length-1));
	// Below this line is all psuedo code
	var new_file_string;
	forEach(sliced_array, function(line, index){
		new_file_string += line + "\n"; // Add each line to the string, one by one
	var new_path = job.createPathWithName("whatever.txt");
	File.write(new_path, new_file_string, "UTF-8");
	// Send job to next flow element
	job.sendToSingle( new_path  );
mkayyyy
Re: Need help breaking text file with multi lines into individual one line text files
Post by mkayyyy » Thu Oct 03, 2019 11:03 pm
Just replied open-automation/Lobby but thought I'd put it here as well. This script will output the text files as you're wanting:
function jobArrived( s : Switch, job : Job ) {
    // Construct file object from path of incoming job
    var inFile = new File(job.getPath());
    // Open the file and read contents into array
    inFile.open(File.ReadOnly);
    var lines = inFile.readLines();
    inFile.close();
    for (var i = 0; i < lines.length; i += 1) {
        // Create temp path
        var lineFileName = job.getNameProper() + "_" + (i + 1 < 10 ? "0" + (i + 1) : i + 1) + ".txt";
        var lineFile = job.createPathWithName(lineFileName);
        // Write contents of current line to temporary file
        File.write(lineFile, lines[i], "UTF-8");
        // Send temporary file to outgoing connection
        job.sendToSingle(lineFile);
    // Send incoming job to null
    job.sendToNull(job.getPath());
Zoranj
Post by Zoranj » Fri Oct 04, 2019 1:37 am
Awesome help Mathew, thank you very much.
Not to be too greedy, but can you edit add function to remove blank lines as well? :oops:
mkayyyy
Post by mkayyyy » Fri Oct 04, 2019 9:11 am
No problem, sure that's pretty straight forward:
    inFile.close();
	// Create a counter variable for file name suffix
	var counter = 1;
		// Check that current line isn't blank
		if (lines[i] !== "") {
		    // Create temp path
			var lineFileName = job.getNameProper() + "_" + (counter < 10 ? "0" + counter : counter) + ".txt";
			// Add one to counter
			counter += 1;
Zoranj
Post by Zoranj » Fri Oct 04, 2019 1:57 pm
This works like a charm.
Much appreciated Mathew.
Saved me some significant time.
Let me know if I can repay somehow.
