Save as older Illustrator EPS
Terkelsen
Post by Terkelsen »
I'm looking for a script that can save a PDF as an Illustrator EPS but in an older Illustrator version than the one installed. Anyone?
Re: Save as older Illustrator EPS
Try this in Switch as a Save As Script for Illustrator, it will save it as AI8 but that can easily be changed to something else..
// Save as Ai 8
var dest = $outfolder + "/" + $filename + ".ai";
var originalInteractionLevel = userInteractionLevel;
var saveName = new File ( dest );
userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS;
saveOpts = new IllustratorSaveOptions();
saveOpts.compatibility = Compatibility.ILLUSTRATOR8;
saveOpts.generateThumbnails = true;
saveOpts.preserveEditability = true;
$doc.saveAs( saveName, saveOpts );
$outfiles = [dest];
Or save it as an EPS from Ai8
// Save as Ai8 EPS
var dest = $outfolder + "/" + $filename + ".eps";
saveOpts = new EPSSaveOptions();
$outfiles = [dest];
Or for Ai CS6
// Save as Ai 8
saveOpts.compatibility = Compatibility.ILLUSTRATOR16;
$outfiles = [dest];
Terkelsen
Post by Terkelsen »
Thanks a lot, Jan. This seems to work perfect for all versions prior to 17 (the first CC version). Do you also know how to change it to work with the CC-versions?
Just change "ILLUSTRATOR16" to a later version number I think the latest is 19
Terkelsen
Post by Terkelsen »
That's how I thought it would work, but if I change Compatibility.ILLUSTRATOR16 to Compatibility.ILLUSTRATOR19, Switch will give this error:
Error 1320: Invalid enumeration value
Line: 40
-> saveOpts.compatibility = Compatibility.ILLUSTRATOR19; (5001)
Maybe there is something with the Configurator.
According to documentation it should work with Compatibility.ILLUSTRATOR19
I can only get it to work up to Compatibility.ILLUSTRATOR16 with my Switch 2019 Fall and Illustrator 2020
https://illustrator-scripting-guide.rea ... patibility
Adobes latest Scripting documentation is for 2017.
Check with Enfocus Support
Mihail_Vereten
Post by Mihail_Vereten »
Thank you so much! Great script
jan_suhr wrote: Mon Mar 02, 2020 8:19 am Try this in Switch as a Save As Script for Illustrator, it will save it as AI8 but that can easily be changed to something else..
// Save as Ai 8
$outfiles = [dest];
// Save as Ai8 EPS
$outfiles = [dest];
Or for Ai CS6
// Save as Ai 8
$outfiles = [dest];
