How to POST a file to an API (Content-Type: multipart/formdata)
Posted: Tue Mar 31, 2020 10:54 pm
by bkromer
Hello Everyone,
I try to upload a file to ninox (https://ninox.com/) a cloud database with a REST-API (docs: https://ninox.com/de/manual/ninox-api/rest-api). Content-Type must be multipart/formdata.
I tried:
	// VIA API TO NINOX DATABASE
	var theHTTP = new HTTP( HTTP.SSL );
	theHTTP.authScheme = HTTP.OauthAuth;
	theHTTP.authorization = "Bearer "+apiKey;
	theHTTP.setAttachedFile( job.getPath() );
	theHTTP.url = "https://api.ninoxdb.de/v1/teams/asdFGW849643dad/databases/fwa469844dawd/tables/C/records/76/files";
	theHTTP.setPostData("Content-Type: multipart/form-data");
	theHTTP.post();
	while( !theHTTP.waitForFinished( 3 ) )
	       job.log( 1, "API CALL IN PROGRESS!" );
	if( theHTTP.finishedStatus == HTTP.Ok && theHTTP.statusCode == 200 )
			job.log(1,"API CALL successfull RESPONSE: "+theHTTP.getServerResponse().toString( "UTF-8" ));
	else
		job.log(3,"API CALL Failed:  "+theHTTP.getServerResponse().toString( "UTF-8" )+ "  Status Code: "+theHTTP.statusCode.toString( "UTF-8" ));
// outgoing conn
I get an error:
31.03.2020 22:33,Error,,Test Flow,Script Element,00001,sc1.jpg,Error in line 10 of script : No matching slot found_ available overloads are:; void SHTTP::setPostData(Utility8::SByteArray_QString);
Does anybody know how to handle those Multipart/form-data posts? I have no clue. :?
It works in postman. But it's easy there.
Kind regards
Ben
Re: How to POST a file to an API (Content-Type: multipart/formdata)
Posted: Wed Apr 01, 2020 8:07 am
by Padawan
Hi Ben,
Can you try this?
	theHTTP.setAttachedFile( job.getPath() ); // You can add the multipart form name as a second argument
	theHTTP.enableMime = true;
	theHTTP.post();
	else
// outgoing conn
I didn't really check the ninox documentation, but this should be the correct way to do multi part form according to the Switch scripting documentation.
Interesting that you want to use Ninox, I looked at it in the past but my customer didn't want to move forward with it. Would you mind explaining your usecase?
Posted: Wed Apr 01, 2020 9:20 am
by bkromer
Thanks for your reply Padawan.
This doesn't work, I also tried putting in the filename as second argument for the "setAttatchedFile()" function.
But I guess that was not what you meant with "...multipart form name..." right?
	filename = job.getName();
	theHTTP.authorization = "Bearer "+apikey;
	theHTTP.setAttachedFile(filename,job.getPath() ); // You can add the multipart form name as a second argument
	theHTTP.url = "https://api.ninoxdb.de/v1/teams/uvasdarz7twsCfQ/databases/j8bert0e3uxf60/tables/C/records/37/files";
	theHTTP.post();
	else
// outgoing conn
The use-case is rather simple. I try to replace an Integromat Workflow we use as the scenario running over there is getting quite expensive.
Every time a new file is dropped in a switch folder it creates a png from it and saves both files in a google drive sync folder. Integromat watches this folder looks for the filename in ninox if the filename is found it updates the file and share link if not it creates a new dataset in ninox with the png attached and it also creates a share link to the file in google drive and writes it in a field as well. The database is from the sales department and they create orders within this table and as there are many types of products they cant imagine everyone by the name so they need to have a view.
Also the order documents created in ninox will use the png`s as well.
Posted: Wed Apr 01, 2020 9:21 am
by bkromer
That's the integromat flow:
Posted: Wed Apr 01, 2020 10:39 am
by Padawan
This line is wrong:
the first argument should be the path to the file, the second argument the name of the form field. So it should be this:
theHTTP.setAttachedFile(job.getPath(),filename); // You can add the multipart form name as a second argument
I also don't see anything saying Oauth in the Ninox documentation, so I think you should use HTTP.ProprietaryAuth instead of HTTP.OauthAuth.
This gives the following code:
	theHTTP.authScheme = HTTP.ProprietaryAuth;
	theHTTP.setAttachedFile(job.getPath(), filename ); // You can add the multipart form name as a second argument
	theHTTP.post();
	else
// outgoing conn
Can you try this?
Edit: Also, that is a very interesting usecase, thanks for sharing! Ninox seems like something interesting to keep in mind for future projects.
Posted: Wed Apr 01, 2020 1:22 pm
by bkromer
Yes! It works :)
Thanks a lot Padawan!
Posted: Wed Apr 01, 2020 1:29 pm
by Padawan
You're welcome :)
Posted: Tue May 04, 2021 7:23 pm
by rgpepper
I have a similar question except for two things:
I need to do this without scripting.
I need to provide the HTTP POST as "multi-part/related" to the Muller-Martini "Connex" software (if anyone is familiar with that).
Sending a .jmf file using HTTP POST from the stock "HTTP request" configurator. Tried MIME encoding on/off, no joy.
Posted: Tue May 04, 2021 11:00 pm
by bkromer
Cant find a Documentation for that API. Can you provide some more information on Müller Martini Connex?
...I need to do this without scripting....
Why :?:
Posted: Mon Jun 21, 2021 11:45 pm
by rgpepper
This ended up working:
URL - http://172.##.##.##:55000
Header (this was the final piece to make it work) Content-Type: multipart/related; boundary="____MM-Part-Boundary____"
The main reason I didn't want to use scripting is I haven't conquered that hill yet, and wasn't going to try and drag someone through going back and forth to get it working.
