Illustrator script error sometimes not defined
PdFUser5000
Post by PdFUser5000 »
This is my error reporting code. Sometimes i get the error: Adobe Illustrator: Error 2: error is undefined. Line: 270 -> $status = error;
I can get pass this by temporary adding var error into catch (e). But after awhile when i delete it the script starts working correctly again. Why is this happening?
if($error==null)
    try {
        start();
    catch (e)  {
        //var error
        $error = e.description;
        $status = error;
        doc.close(SaveOptions.DONOTSAVECHANGES);
Re: Illustrator script error sometimes not defined
Granted, the documentation does not specify it specifically, but it seems logical that the content of $error has to be a string:
$error = "error";
and on the next line it has to be $doc instead of doc.
PdFUser5000
freddyp wrote: Mon Aug 10, 2020 9:11 am Granted, the documentation does not specify it specifically, but it seems logical that the content of $error has to be a string:
$error = "error";
$status = "error"; should be correct then? not $error = "error"; ,based on your last sentence.
Sorry, it is indeed $status and not $error.
