Wrong choice of imposition with Phoenix application
Posted: Thu Feb 18, 2021 3:35 pm
I'm trying to impose my files using the Phoenix application in Switch. However, I realize that the result of imposition via Switch flow is not the best compared to imposition with the same files in Phoenix manually where the best result is chosen based on the least amount of material loss or the least cost.
In Switch, application Phoenix simply takes the first one that is generated it seems to me. (ID 1)
I use the same imposition AI profile in both cases.
Have you been confronted with this case ?
Thank you.
Thank you.
