Different values Acrobat - Photoshop - Enfocus Pitstop
Moderator: pietdepauw
giuliano.lorenzon
Post by giuliano.lorenzon » Tue Jan 31, 2017 2:37 pm
I'm going crazy since my company has decided to check the Total Area Coverage on every single page we print.
The main problem that i found out is:
I have different values If i measure a CMYK area with:
Acrobat Output Preview
Enfocus Pitstop
Photoshop
Has someone experience on these cases?
Best
Giuliano
bens
Re: Different values Acrobat - Photoshop - Enfocus Pitstop
Post by bens » Wed Feb 01, 2017 10:18 am
The amount of ink produced by a specific colour in the PDF are very much dependent on the colour management settings. If PitStop and Acrobat use different ICC profiles to calculate the values, then the result will be different. Make sure the colour management settings are exactly the same in every application you use to check the ink coverage.
Also note that Photoshop doesn't deal directly with PDF files, so it may not know about some PDF constructs that can have an effect on the colour.
For more information see this article: https://supportportal.enfocus.com/Suppo ... 000jfccIAA
giuliano.lorenzon
Post by giuliano.lorenzon » Wed Feb 01, 2017 12:10 pm
On two machines with windows 10 Acrobat DC i set the same color setting but now the eyedropper tools close me down Acrobat.
bens
Post by bens » Fri Feb 03, 2017 12:30 pm
Acrobat's output preview window is notoriously buggy (and seems to be getting worse over time). Try to use the eyedropper without ever opening output preview.
If it keeps crashing I suggest you contact Enfocus support through the support portal.
giuliano.lorenzon
Post by giuliano.lorenzon » Mon Feb 06, 2017 8:30 am
I solved. It was the acrobat colormanagment preferences.
Conversion option was not present into the system.
