Outdated links to Crossroads send me in circles
Moderator: pietdepauw
cwswitch
Post by cwswitch » Wed Nov 08, 2017 1:05 am
I'm quite new to Switch but feel I'd be far further ahead with good online help.
Instead this is what happens.
Search online
result
which links to corssroads
which links to these forums
I reach this loop to nowhere many times a day. These outdated links are all over the web, in the documentation and even in Switch itself when you look for help or documentation.
enfocus
Re: Outdated links to Crossroads send me in circles
Post by enfocus » Fri Nov 10, 2017 4:48 pm
When you open the manual page of Switch, then you can find manuals for both new and old Switch versions:
https://www.enfocus.com/en/support/manu ... ch-manuals
Google seems to prefer the manual of Switch 11, update 4 over the Switch 17 manual for some reason. We'll see what we can do to fix that.
I would advise to just use the manual of the Switch version you are using, you can find all those manuals on the page I mentioned above.
Can you tell me in which versions of Switch you are seeing links still pointing to Crossroads-world.com?
Zoranj
Post by Zoranj » Fri Nov 10, 2017 7:38 pm
Would it be possible to pull old archive of Crossroads and make it available online so people can extract actions, etc.. before shutting it down again?
I am sure we would even have volunteers to extract and make available to everyone useful scripts, etc..
cwswitch
Post by cwswitch » Tue Nov 14, 2017 2:15 am
enfocus wrote:Can you tell me in which versions of Switch you are seeing links still pointing to Crossroads-world.com?
Switch 13 has a link to Crossroads in the Help menu
Thanks for the other info
enfocus
Post by enfocus » Thu Nov 16, 2017 5:44 pm
This is what happened to the content of Crossroads:
- Everything from the forum is transferred to forum.enfocus.com
- Most of the flows where related to configurators. Our solution partners have provided updated sample flows using their configurators and these are available on Enfocus.com, on the pages of their configurators. This is an example of such a page:
https://www.enfocus.com/en/products/swi ... nter#flows
