Adding multi-line text to PDF with VariableSets
jterrano
Post by jterrano »
I am attempting to apply multi-line text to an action list through a variable set.
The multi-line text shows :
in x-path :
<Column Name="DetailDescription" DataType="STRING">LUX_CP 3030347
Standard Hours Sign
18"x30"
.020 Stryene Dead White
4/0
4-Holes Drilled in Corners</Column>
as utf-8 :
<Column Name="DetailDescription" DataType="STRING">LUX_CP 3030347&#13;
Standard Hours Sign&#13;
18"x30"&#13;
.020 Stryene Dead White&#13;
4/0&#13;
When i attempt to apply DetailDescription to private data, I am given an error that states that the following lines must start with a key=tag
Standard Hours Sign
18"x30"
4/0
When i attempt to apply the DetailDescription as a variable set, pitstop will only pull the first line in "LUX_CP 3030347"
I've tried changing the &#13 to &#133, which from what I have found is a utf-8 encoding:
&#13 = Control character: Carriage Return (cr)
&#133 = Control character: Next Line (nel)
I have exhausted all options as far as i can think and really hope someone may be able to provide assistance... overall the goal is to take this multi-line detail description and write it to a PDF as i am attempting to generate job tickets for production.
JimmyHartington
Re: Adding multi-line text to PDF with VariableSets
Post by JimmyHartington »
As far as I know it is not possible to add multilines in with Pitstop.
If you create the jobticket from scratch maybe it is better to write a HTML and convert it to PDF with tools for that.
I have used custom written HTML with web-fonts, converted to pdf with Chrome and lastly placed into an existing PDF.
This way I could achieve multilines pdf from Switch variables.
john.dean@esko.com
Post by john.dean@esko.com »
Adding multiline text in PitStop is indeed on the feature request list that is being reviewed.
Somewhat familiar with Enfocus products.
Malcolm Mackenzie
Post by Malcolm Mackenzie »
I've done this line by line.
Bit fiddly but once done it worked.
It might help someone here.
Add object and set offset.
Add object change offset up/down or across
Screenshot 2022-05-27 at 15.39.35.png (40.82 KiB) Viewed 2678 times
