Selection and removing CMYK objects apart from spot objects
Kazuar
Post by Kazuar » Fri Mar 10, 2017 9:41 am
Hello.
Is it possible to create an Action, which will be removed from the file, for example, CMYK+1_Spot
all raster and vector objects painted CMYK, but at the same time leaving all vector Spot objects?
bens
Re: Selection and removing CMYK objects apart from spot objects
Post by bens » Fri Mar 10, 2017 4:23 pm
Select images
Remove selection
Select by color space: CMYK
Remove selection
Terkelsen
Post by Terkelsen » Wed Apr 05, 2017 2:40 pm
You could either do as bens suggests to select everything you want to remove or maybe it is more safe to remove everything BUT the things you want to keep. The later could be done with an action like this:
Select all
Select line art
Select all spot colors
AND
NOT
Remove selection
Using this method you could choose to also preserve all text in spot colors
Select all
Select line art
Select text segments
OR
AND
NOT
Remove selection
