Checking bleed
Posted: Tue May 16, 2017 2:43 pm
by jslater
Hello, I am setting up a workflow to QC files before they move into imposition, and one of the checks I need to perform is checking that there is enough bleed in the file. I know there's the "Select Objects Close to Page Edge" action, but it actually warns the wrong way. In other words, it throws a warning when the bleed is good instead of when it's bad. Is there a way I can set up the action list so it only warns when there is too little bleed?
Re: Checking bleed
Posted: Mon May 22, 2017 3:58 pm
by enfocus
If you wish that Enfocus checks why your Action List is not working, please contact us via the Support Portal:
https://www.enfocus.com/supportportal
Re: Checking bleed
Posted: Mon May 22, 2017 8:01 pm
by jslater
Thank you, but I think I got it worked out. It's worked on all my test files, and I'll see what happens when it goes live.
