Hi, what would be the best way to flatten transparencies? Example: This file. http://prntscr.com/lf03an - looks all good in pdf, but when printed or even opened in coreldraw, this is what I get: http://prntscr.com/lf03gi
Any ideas how to flatten transparencies the correct way? Till now, I've been using this: http://prntscr.com/lf03wc - in switch, pitstop server.
Thanks for any ideas/help.
Flatten transparencies?
Re: Flatten transparencies?
PitStop Pro doesn't contain any transparency flattening because Acrobat itself already has it. You need to open the Acrobat "Print Production" tools and then use the "Flattener Preview" button to see the functionality.
PitStop Server uses the flattening library from Adobe, so the results you get with Acrobat and PitStop Server should be very similar.
