PitStop not selecing RGB elements
RytisT
Post by RytisT »
Hello. I have a rookie problem, my pitstop is not selecting RGB elements. Now, I know it's probably that I don't have the right "select" action set, is why it won't select, so maybe you can help me out.
All I have in PDF is "ICCBased RGB" - that's what Acrobat tells me. And I have in action list, these actions:
http://prntscr.com/lqkfr2
http://prntscr.com/lqkfun
http://prntscr.com/lqkfzm
Any ideas where I could move on with this?
Terkelsen
Re: PitStop not selecing RGB elements
Post by Terkelsen »
It's probably because you are selecting objects that have BOTH fill and stroke in the chosen color space. If an object has fill but no stroke or visa versa, it won't be selected. You will need to divide it in to two parts in your action, selecting objects that has RGB fill OR objects that has RGB stroke.
RytisT
Post by RytisT »
Good idea, but that wasn't it. Selecting only fill color, RGB object still doesn't get selected.
abailescollins
Post by abailescollins »
Can you post the file so we can look?
abc@imposition.com
RytisT
Post by RytisT »
Sure, thanks: https://we.tl/t-SHy7wp8T6w
There's loads of RGB objects, but for example one of them is "500g" but I can't find a way to select it. Thanks.
Padawan
Post by Padawan »
I checked your file and I think Terkelsen is correct.
The "500g" objects are tagged with sRGB in the fill. They have no stroke.
If I setup the "Select by icc tag subtype" to report ICC tagged RGB in the fill and disable the reporting of ICC tagged RGB in the stroke, then it finds the object.
I've created an Action List which illustrates how you can handle this. As Terkelsen said, you divide up your Action List so you have one Action for each possibility. Then you combine the selection with OR statements. If you don't do this, then only the objects with both ICC tagged RGB in the fill and ICC tagged RGB in the stroke will be selected.
https://ufile.io/drt8s
I've also created a version which will search for all kinds of RGB objects:
https://ufile.io/dhj4u
RytisT
Post by RytisT »
Hm, weird, because I did try it it without stroke option, oh well, thanks a ton for the help.
Thanks.
